Vacuum Governed Pumps on Fordsons
Brian
08-27-2000 02:08:01
Chaps,
May be teaching my "grandmother to suck eggs" but here is a way to check the governor diaphram without striping too much down.
Remove the two governor pipes at the pump.
Move the stop control to the "stop" position and seal the governor pipe hole with your fingers.
Release the stop control.
If it stays back, diaphram OK
If it moves to the "run" position, either fingers are leaking or diaphram faulty.
regards
Brian
Oscar
08-31-2000 01:48:40
 Re: Vacuum Governed Pumps on Fordsons in reply to Brian, 08-27-2000 02:08:01
Excellent tip, Brian!
Steven B
08-28-2000 14:08:08
Noted. Good advice.
