Which fordson?
Dave
08-28-2000 01:30:04
My dad has just given my father in law an old fordson tractor. We wouldn't have a clue as to its age etc, but it is in pretty good condition- motor turns, and was run periodically until the early eighties. Cast in the left side of the block, below the word Fordson, is a number 3, and aft of that the code F23J. Higher on the block is stamped 6015- I can't make out if there is a cast prefix. There is also K29J cast in (on memory) the bellhousing.
Any information would be greatly appreciated, Oh yeah, some idea of its approximate weight would also help.
thanks in anticipation
Dave O'Meara
Brian
08-28-2000 03:18:29
 Re: Which fordson? in reply to Dave, 08-28-2000 01:30:04
Dave,
Your casting numbers give May and August 1963 so it looks like you have a Grey Wheeled Super Major.
Your engine number on the block should be something like 08C967835. The 6015 could be part of a number (08C)(9)6015(-) This would date the tractor engine in June 1963 which ties in with the code May 23rd 1963. The other casting number of August 29th 1963 is a bit late to tie up with the other numbers but again it is possible that a new gearbox housing has been fitted if the machine had been used on a loader.
regards
Brian
