Super Dexta serial ##
LoRan
09-19-2000 21:37:37
I have tried to find the serial number on this tractor, but there is nothing where everyone tells me it's at. Just smooth metal. The number I do find, and it is stamped all over the thing, is
0957E 7005 T4.
Paul Muscat (Australia)
09-20-2000 13:32:02
 Re: Super Dexta serial ## in reply to LoRan, 09-19-2000 21:37:37
Hi I recently purchased a workshop manual and it covers the Dexta series. According to the manual the "Tractor serial number is stamped on the left side of the clutch housing flange and prefixed by model number. Engine serial number is stamped on the left hand side of cylinder block."
hope this helps
Don(CO)
09-20-2000 08:11:57
The 975E simply indicates it is a Diesel fitted tractor. The serial number will be on the left hand side of the engine/transmission housing flange. It is stamped vertically on that flange, beginning with 957E near the top of the flange.
You may need to scrape this flange and wire brush vigorously to expose the numbers from repaint buildup, grease and dirt.
There is a chance the serial number could have been ground off..... if that is the case: This tractor, at some time in it's life... was most likely stolen. Add's to the history of tractor though! :-)
