Jack-- Hello Jack
Burrhead
10-19-2000 14:17:56
Bonjour Jack.
Sorry for being so late to answer, but I have been exceptionally busy, especially for a old fat man. I think I'll retire again someday.
It sounds like everything is ok with the fuel.
Do you use the glow plug also??? or just the primer.
If you use the tractor in cold weather it might be a pretty good move to put a block water heater on it.
The weather here went down to 77 the other night. I will have to put on my insulated step-ins if it gets 30 degrees here.
Jack.C
10-20-2000 07:47:32
 Re: Jack-- Hello Jack in reply to Burrhead, 10-19-2000 14:17:56
Hello Burrhead
No problem I'm busy too at this time of the year.I used the heater and the primer pump, I also hear the small diesel explosion in the intake (mean that my heater work), it turn but doesn't start this is even when I hold the heater "on" while starting the only way I get it to start is when I force the fuel in the intake with primer.That is why I suspect the fuel system to be empty. This is when she is not being used for more than 2 days.I don't know if the temperature as someting to do with this,I hope not I was about to use it in winter and the temperature is a lot lower than that here in winter.
Regards
Jack.C
