NOT FULL POWER W/POPING SOUNDS
RICHARD HALL
10-25-2000 12:54:26
This happen after i fill about 5 gals of fuel in about 15 mins later it stated to pop and lose power. What to do?
Greg Siekeirko
10-31-2000 19:04:03
 Re: NOT FULL POWER W/POPING SOUNDS in reply to RICHARD HALL, 10-25-2000 12:54:26
My Fordson Dexta did this to me last year it turned out to be the coil going bad. As the engine heated up the coil got too hot and did not work. Try using a new or different coil. you can use an auto coil as long as it is 12 volt and has the correct connections to match your harness. You might also try your plugs and wires. One could be bad. If the problem contiues you can also check the point gap and condition.
