Leo, Your County
Steven B
11-02-2000 18:15:54
Leo
Your Super Four that now has a six cylinder, is it live drive? Also, did you put the bigger radiator in it? And, is the engine the late Thames Trader type with mechanical govenor or the early pre 1962 with the pneumatic govenor.
Just noesy
Thanks
Steven
Leo
11-10-2000 23:57:04
 Re: Leo, Your County in reply to Steven B, 11-02-2000 18:15:54
I bought Super 4 new because it had LD and converted while new to 6 cyl. The reason I did this was first, price Super 6 was a lot dearer, you could not get Super 6 with LD and it was far cheaper to convert to 6 that way than convert 6 to LD. The engine used was one of the last 590 mech. govern. engines.
I used the original radiator but used Hi cap. 6 blade fan and have never had any heating problems. I used two Fordson bonnets and joined together and used original Fordson radiator cowl. The reason being to keep visability as good as possible. In the cowl I used two internal lights and the external lights. As well as manual instrument panel through fuel tank, I used early type panel under the fuel tank showing oil pressure gauge, normal water gauge was used a oil temp gauge and also the amp meter. The SM hyd. system was replaced with Power Major hyd. system which is less complex and suited our work and is far more reliable. I still have the tractor but don't use it as much as I used to. Regards, LEO
Steven B
11-12-2000 13:48:11
 Re: Re: Leo, Your County in reply to Leo, 11-10-2000 23:57:04
Thanks. What did you do with the sump, is it the truck type?
Steven
Leo
12-03-2000 03:30:21
 Re: Re: Re: Leo, Your County in reply to Steven B, 11-12-2000 13:48:11
County 6 cyl. sump was especially made by County to Suit Super 6 and has no relationship to any truck sump. It was a rear well and flared out at sides to get capacity. Not real good on steep country as you lose oil pressure. Regards, LEO
