Super Dexta
Chip
11-05-2000 08:59:42
I went out to start my Super Dexta yesterday,(it is a three cylinder diesel) and it made a hissing/popping noise and would not start. I noticed white smoke coming from a plate beside the exhaust manifold. the plate has three bolts in a triangular pattern. it appears the "gasket" behind the plate has blown. My question is what is it,where can I get another one and why did it blow. Please help.
Burrhead
11-05-2000 17:44:14
 Re: Super Dexta in reply to Chip , 11-05-2000 08:59:42
I forget the real name for the combustion chamber behind the plate you're talking about. You'll need to fix it or that cylinder will miss because of low compression.
Perkins Diesel, Ford or Massey all have the new gasket.
They just get old and weak and sometimes blow out. It's no big deal unless you were using ether to crank with.
The Perkins engine will blow that particular gasket from over compression when you use ether, and it probly bursted the piston too if ether caused the gasket.
