Fordson 58 Super Major Diesel
Ivan
11-09-2000 11:57:29
Cannot get the three point hitch to go up or down. I do have the pto lever in position. Any help would be appreciate
Leo
11-11-2000 00:07:17
 Re: Fordson 58 Super Major Diesel in reply to Ivan, 11-09-2000 11:57:29
There is two Super Majors hyd. systems, they are a very troublesome hydraulic system - particularly if they have done a lot of work. If you intend to use for work, would replace the whole hyd. system with the Power Major type. If you want retain original system, strip complete top cover and hyd. pump. Replace all o rings and worn parts and reset to factory specs. as the control valve will be either sticking or is too badly worn. Make sure back end is not full of water i.e. oil is milky. Depending the temp. where you live, if warm climate over winter use 80/90, very hot climate 90/140, cold climate engine oil. Hope this helps. LEO
JT
06-21-2003 15:12:18
 Re: Re: Fordson 58 Super Major Diesel in reply to Leo, 11-11-2000 00:07:17
Just for the record you do not use gear oil for hyd. oil. You should use Ford/New Holland 134 oil.
