Joel Mattingly-Super Six
Steven B
11-28-2000 03:29:17
Joel
Continuing on from below, if you can get the original oil pan, don't hesitate. Unfortunatly, it will not fit the later Dover engine, the later engine has a diferent casting around the oil pump and the timing gear housing. I think you should try to get the original engine. I would play around with a Dover as a last resort. I have seen plenty of Fordson Super Majors that have had the six transplanted straight out of a truck. I will look at one of my engines this weekend and get back to you. I can see that maby the truck pan will foul the front axle on the four wheel drive.
Steven B
