Fordson Tractor
Donald Chestnut
12-17-2000 08:22:05
Just acquired Fordson Tractor on steel wheels. Would like info as to how and where to locate the serial number.
ADAM
12-17-2000 19:08:36
 Re: Fordson Tractor in reply to Donald Chestnut, 12-17-2000 08:22:05
The tractor serial number is located on the right side of the engine block, stamped onto a flat surface between the first two manifold runners.
Beware, engines were swapped often and the area where the number is stamped is prone to rust and pitting making the numbers hard to read. Do you have the production chart to determine the year of your tractor???
Don Chestnut
12-20-2000 14:53:21
 Re: Re: Fordson Tractor in reply to ADAM, 12-17-2000 19:08:36
ATTENTION: ADAM
Thank you for responding. No, I do not have a Production Chart. Do you know how/where I can obtain one?
I'm not sure if I am doing this right to ask another question. I am new at getting on the message boards.
Thank youl
Don Chestnut
ADAM
12-21-2000 19:22:06
 Re: Re: Re: Fordson Tractor in reply to Don Chestnut, 12-20-2000 14:53:21
when you find your serial number just post it on this message board and one of the many nice Fordson guys that visit this site often can determine what year Fordson you have.
you must be doing somthing right!! I saw your message!!
Dave Wolfe
12-22-2000 23:19:29
 Re: Re: Re: Re: Fordson Tractor in reply to ADAM, 12-21-2000 19:22:06
I have also just aquired a steel wheel Fordson and didn"t know where the SN was This Websits has a list of SNs I found out mine is a 1925
Dave from Australia
