Simms Injector Pump problem?
Nellie
03-10-2001 08:39:12
My Fordson has a later model Simms pump on it, it has oil in it with a drain and check level screw. My problem is my tractor quit, died down slowly and I have not been able to restart it. I found a loose connection from the block to the fuel tank. I tighned that back up. I have a electric fuel pump on it and I bled the injector pump by cracking open the two purging screws. It is getting plenty of fuel up to that point. I cracked open a high pressure line going into the #2 cyl. I find very little fuel at this point.
I don't see any leaks, or bubbling any place else. My oil level in the Inj. pump was low but not dry, no metal finds. I refiled it with new oil. Still not starting. (It will start with spray into the intake but not from fuel the injector system). How robust are these Simms injector pumps? What else should I try?
Jake Wilson
01-22-2006 21:01:12
 Re: Simms Injector Pump problem? in reply to Nellie, 03-10-2001 08:39:12
These do not have glo plugs but have a heater in the intake air flow. Check to see if the heater is working
john
03-15-2001 13:26:59
i have a simms injecter pump on my fordson to but the easiest way to find out if it is the pump is to take it and have it checked by an injecter service person i had mine checked an it was fie and he put a new govoner diaframe in it and it only cost about $60.00. so any way i hope i have helped you out.
Cold start Button not working
03-11-2001 04:05:24
Another clue I forgot to add. The cold start or over fuel button will not stay in anymore. It use to work fine.
degeezer
05-22-2005 21:09:37
 Re: Re: Simms Injector Pump problem? in reply to Cold start Button not working, 03-11-2001 04:05:24
Forgot to add that if the bar inside the pump that moves back and forth to adjust the fuel flow does not get pushed by the governor , the cold start button won't stay in . If the button won't stay in , the bar is not moving for some reason .
