Identification serial number
SARLET JEAN MAR
03-17-2001 10:15:35
I have a fordson super major (disk brakes) with the serial number S400707 (under 1° inject).
I leave in BELGIUM, could somebody tell me more about this serial number.
Jim
03-17-2001 20:01:36
 Re: identification serial number in reply to SARLET JEAN MARIE, 03-17-2001 10:15:35
That sounds like a casting number. The serial number should be stamped either on the right front side of the engine where the block meets the head on a flat boss or vertically on the clutch housing on the left side. Serial numbers are stamped and casting numbers are cast into the metal.
Brian
03-18-2001 02:10:31
 Re: Re: identification serial number in reply to Jim, 03-17-2001 20:01:36
Jean-Marie,
The number you have is either a number from a replacement engine or one from a "skid unit". This was a tractor supplied to someone like Roadless or County for building into another machine. Have you a number on a small plate on the battery fire wall or is it possible your tractor is a "none standard" unit?
regards
Brian
