WHAT YEAR IS MY FORDSON MAJOR D
LARRY C
03-22-2001 19:47:48
HI I JUST PURCHASED A FORDSON MAJOR D AS IT IS MARKED ON THE SIDES OF THE ENGINE COVER . IT HAS A DEISEL 4 CYLINDER AND A 3 SPEED GEAR BOX WITH A HIGH AND LOW RANGE.IT ALSO HAS VANES IN FRONT OF THE RADIATOR THAT ADJUST WITH A LEVER . ANY INFORMATION WOULD BE HELPFUL. THANKS IN ADVANCE /LARRY
Ian Slater
04-02-2001 19:37:38
 Re: WHAT YEAR IS MY FORDSON MAJOR D in reply to LARRY C, 03-22-2001 19:47:48
Hi, Larry,
Just read the other emails and noticed you have already found the information you were looking for. I have a Fordson Super Major 5000, 1963, and am pretty keen on the tractor.
Ian
Brian
03-23-2001 11:41:16
Sounds like it is around 1953. Just behind the starter on the flange is a number. Post this and we can get it down to the month of production.
regards
Brian
LARRY C
03-31-2001 20:27:50
 Re: Re: WHAT YEAR IS MY FORDSON MAJOR D in reply to Brian, 03-23-2001 11:41:16
HI BRIAN FINALLY FOUND THE SERIAL # IT IS 1340255 HOPE THIS HELPS PLEASE LET ME KNOW WHEN IT WAS MADE . THANKS IN ADVANCE/LARRY C
LARRY C
03-31-2001 20:26:59
Brian
04-02-2001 00:36:57
 Re: Re: Re: WHAT YEAR IS MY FORDSON MAJOR D in reply to LARRY C, 03-31-2001 20:26:59
Larry,
You have a May 1955 tractor. Whenever you get parts etc. it will be helpful to quote this number.
regards
Brian
larry c
04-02-2001 20:13:38
 Re: Re: Re: Re: WHAT YEAR IS MY FORDSON MAJOR D in reply to Brian, 04-02-2001 00:36:57
thanx brian appreciate it/larry
larryc
03-26-2001 16:45:51
thanx brian for the info I havent been able to find the flange you were talking about . the tractor has a loader on it that is kind of in the way I will have to remove it since the tractor requires some work I believe it needs a clutch it tries to move but not much and the engine does not seem to even know it is in gear .got any pointers on how to do this. I knew its condition when I bought it it runs great needs some cosmetics not much paid $1000 for it figured I could get that out of the loader .any help would be appreciated thank you/larry
