FSM Manifold Gasket Needed
Bill
04-10-2001 19:42:42
The in/ex manifold gasket is not available any longer from Ford. Do any of you have one to spare or best of all, know a source. Is it possibly a design I can cut from sheet material. I have not removed it yet to prevent disabling the tractor. Is there a possibility that the Dorset Ford engine uses the same or workable manifold gasket? BTW, I'm in the USA. Any help is much appreciated. Bill
Steven B
04-14-2001 15:38:31
 Re: FSM Manifold Gasket Needed in reply to Bill, 04-10-2001 19:42:42
Bill
I am sure a 4cyl Dorset will do. New FSM gaskets are available through New Holland though.
Bill
04-14-2001 20:06:43
 Re: Re: FSM Manifold Gasket Needed in reply to Steven B, 04-14-2001 15:38:31
If the Dorset gasket will work I know where to get that. The Ford/New Holland dealer I get other parts from came up with "code 44" meaning "no longer available". So I did go that route first. Thanks for your help. I'll try the Dorset gasket next.
Roger
04-27-2001 05:52:40
 Re: Re: Re: FSM Manifold Gasket Needed in reply to Bill, 04-14-2001 20:06:43
Hi Bill
Readily available from my local New Holland dealer here in Australia. Comes in a plastic sleeve showing "Made in U.K.", and surprisingly inexpensive. Most of the little bits and pieces I've recently bought (thermostats, radiator cap, etc, are all genuine, and cheaper than similar types of generic automotive replacement bits at the local auto-parts barn.
Let me know if I can help any.
Cheers
Roger
Mike in Hallsville, Misso
08-05-2006 08:29:18
 Re: Re: Re: Re: FSM Manifold Gasket Needed in reply to Roger, 04-27-2001 05:52:40
Anyone know of a source for FSM Diesel parts? Need complete Manifold Gasket set.
