Diane, Manual is available from 'Oscars Fordson pages' - look for posts on this board from Oscar for a link. Pick a very recent post though, as he moved the page to a different server about a month ago. The level plugs (square top) are on: - the left side in front of the power take-off lever for the rear axle and hydraulics, about 1 hand span up from the foot plate. The fill plug is on the top of the differential. - the right hand side at about the same height and about in line with the gear levers for the gearbox. The fill plug is on top of the gear box. The fluid levels are right when the fluid reaches these plugs with the tractor on level ground and not running. I found it easiest to undo the level plug and then slowly fill the area until the fluid started to run out of the hole. What problems are you having with the hydraulics? Steve
