1955 FORDSON MAJOR BRAKES NEED PARTS HELP
LARRY C
04-17-2001 21:39:34
I have a Fordson major diesel serial #1340255 both brake cables are damaged and left side brake pads are gone looks like the cables were hgooked on something streching them . where can I find parts ? any help would be appreciated 1 more question did all of these tractors come with a horn and compression break lever. this has a horn which says clear hooters limited . and a compression release lever on the engine . thanx in advance . LARRY C
Richard Bedford
04-18-2006 09:14:04
 Re: 1955 FORDSON MAJOR BRAKES NEED PARTS HELP in reply to LARRY C, 04-17-2001 21:39:34
renovating my Fordson Major 1956 mod.need new springs for brake shoes can you help. Regards Richard..
nelson X
04-25-2001 02:21:37
Paul, any reputable brake shop should be able to make new cables for you using your original cable sheaths. just make sure you give them the right lengths and also give them the old cables so they can duplicate the correct cable ends. As far as brake shoes go get new non asbestos ones from the same shop, again supplying your old ones as a pattern. be careful when handling your old ones because if they are original they will be asbestos. It will also probably be neccessary to turn out the brake drums to accomodate the new shoes any good engineering shop will do this for you.I took 5mm out of both mine and the brakes turned out better than new!! The whole job cost less than $75NZ. Good luck.
larry c
04-25-2001 13:00:13
 Re: Re: 1955 FORDSON MAJOR BRAKES NEED PARTS HELP in reply to nelson X, 04-25-2001 02:21:37
thanx nelson I have found a shop that will make new cables and reline shoes . unfortunately it will cost a little $100 U.S. BUT BETTER THAN THE $100 PER CABLE FORD WANTED. APPRECIATE THE HELP THANKS AGAIN.LARRYC
Nelson X
04-25-2001 02:24:53
whoops sorry Paul I should be talking to Larry C
Harold Brockwell
04-23-2001 16:28:53
Larry I owned 2 fordson majors purchased new yes all come with compresson releases horns and parking lights,sims injection fuel pumps and lucas electrical systems all made inU.K no help for brake parts. i may be some help on repairs Harold B.
larry c
04-23-2001 21:13:21
 Re: Re: 1955 FORDSON MAJOR BRAKES NEED PARTS HELP in reply to Harold Brockwell, 04-23-2001 16:28:53
thanx harold b I will keep your name handy I like working on things especially this and am looking forward to getting it going .larry c
Paul
04-22-2001 18:51:21
If it's a 1955 it will have drum brakes. The cables are available from Ford at a price. The brake shoes are not. What do you need?
Paul
Paul
04-23-2001 06:06:47
 Re: Re: 1955 FORDSON MAJOR BRAKES NEED PARTS HELP in reply to Paul, 04-22-2001 18:51:21
Call L.J. Hand Farm Center, Inc. @ 1-800-724-1080. They have a Major that has the right cable intact. You'll be best serviced to have the shoes relined.
Paul
larry c
04-23-2001 21:09:47
 Re: Re: Re: 1955 FORDSON MAJOR BRAKES NEED PARTS HELP in reply to Paul, 04-23-2001 06:06:47
thanx for the help paul
larry c
04-22-2001 20:54:34
hi paul I need both cables and 1 set of brake shoes I guess I could get the shoes re lined but I do need both cables. thanx /larry
