Hydaulic pump on FPM
Shane
04-23-2001 21:04:59
Hello everybody,
I am after some details on how to remove the hydraulic pump for repair on the FPM. I havn't been able to get a manual to help me so is it accessable from underneath the seat or do I have to split the tractor?
Brian
04-28-2001 02:19:44
 Re: Hydaulic pump on FPM in reply to Shane, 04-23-2001 21:04:59
Shane,
Take the lift off and delve down into the oil to remove the mounting bolts. It will come out quite easily but you will have to rock it as it mounts on dowels. If you need to clean the filter, drain the oil and remove the four bolts holding the filter underneath the tractor. Its the plate with the drain plug in it. There are also two magnetic filter bolts just in front of this plate that can be removed and cleaned.
regards
Brian
