Fordson Major engine number???
Clas Uddenas
04-28-2001 03:28:33
I have bought an old Fordson Major -56 (they told me). I am unsure about the engine because the original was replaced with a diesel engine.
I would like to know when and where the engine is produced.
I found some numbers on it:
GD50J
J3167
I am not sure (hard to read).
Is there anyone who can help me find out something about this engine?
Best regards,
Clas
Brian
04-29-2001 02:56:12
 Re: Fordson Major engine number??? in reply to Clas Uddenas, 04-28-2001 03:28:33
Clas,
The "where" is easy. It will have been built at Dagenham in England.
The numbers you quote are not related to any given although I would suspect that you are reading some of them wrong. They are sometimes hard to read.
Your engine, if produced after 1956, should have a flat machined area under No.1 injector. Any number stamped here will tell us the date of the tractor the engine was first fitted into. If it was a "skid unit" however this will not help.
The casting numbers are on the manifold side of the engine and should read something like : L19T. This decodes as September 19th 1952. After 1963 the casting codes would read: 3G19 which decodes as 1963 July 19th.
Your J31(67) Could be July 31st but the 67 is wrong.
Hope this helps.
regards
Brian
Clas Uddenas
05-08-2001 02:27:25
 Re: Re: Fordson Major engine number??? in reply to Brian, 04-29-2001 02:56:12
I found a stamped number on the manifold side:
4F1
Over that there is an "A" in a metalic ring and
under a big stamped "A".
Is this the right number?
Clas
Brian
05-09-2001 10:45:35
 Re: Re: Re: Fordson Major engine number??? in reply to Clas Uddenas, 05-08-2001 02:27:25
Clas,
Non of the numbers you quote are casting codes or Fordson engine numbers. Have you a Fordson engine or was the engine replaced with a Perkins L4 or 4.270?
regards
Brian
