Fordson Serial Number
John Barrett
04-29-2001 06:13:52
I have purchased a Fordson Tractor (diesel) an have veiwed a nuber of the discussion groups. I believe I have found the serial number; however, I can't find any supporting information?
Please help Serial # s 681325. This is stamped on the right fron side of the engine block below the # 1 injector.
Brian
04-29-2001 08:21:08
 Re: Fordson Serial Number in reply to John Barrett, 04-29-2001 06:13:52
John,
Your number is one of the problem ones. (see post below). Your engine has been replaced by one from a "skid unit" or your tractor was a "skid unit".
Skid units were engine,transmission and rear axle supplied to other manufacturers, County, Roadless, etc.to build into their own machines.
Engines alone were also supplied to New Holland, Class, Ransomes etc. for combines.
Other uses were compressors, pumps and generator plants.There are no concise records for these units and only the casting codes can give an indication of manufacture date.
regards
Brian
