FMD Gear Oil
Spencer
05-21-2001 09:52:57
The gearbox oil level on my 1954 FMD keeps falling, there are no signs of external leaks and the oil level in the crankcase seems to be rising proportionately. As this has only happened since I split the front end and took out the primary gearbox, I am assuming I have damaged the oil seal in the PTO housing under the gearbox and oil is flowing through that. Is there any other likely explanation?
Additionally, do I need to worry? I use a loader and a digger quite a lot, so need to maintain a higher than usual oil level in the back axle to compensate, so can I simply add oil to the gearbox until the levels equalise? Or is that too simplistic?
