FORD DEXTA SERIOUS PROBLEMS
AL
05-21-2001 10:23:26
my dexta wont turn can i loosen up the steering?
Burrhead
05-21-2001 19:20:59
 Re: FORD DEXTA SERIOUS PROBLEMS in reply to AL, 05-21-2001 10:23:26
It's probly seized up on the bottom steering shaft bearing.
You might be lucky enough to pull the steering wheel and pour penetrating oil to it and free it up. I'm not that lucky.
Outside of that you'll need to pull the steering wheel and fuel tank off to get the steering box off of it.
When you get that far along be sure to keep up with the shims on each side under the side cover.
When you get it all cleaned and free the box is supposed to have gear oil in it. I always use chassis grease instead. If you don't live in a cold climate the grease will stay longer and steer easier than gear oil.
