Ford Dexta Clutch
Raymond Bagwell
08-28-1999 21:14:21
I am having problems with the clutch on my Dexta. The pto clutch will disengage but the transmission clutch will not. Any suggestions. This happened while the tractor was being used. Thank you in advance for any help you may be able to give me.
Tim Hinkle
09-21-2005 21:42:07
 Re: Ford Dexta Clutch in reply to Raymond Bagwell, 08-28-1999 21:14:21
I had the same problem with my ford dexta. I as pulling a box scrape when all of the sudden the tractor quit pulling. The clutch felt different. It would still shift into gears but would not pull. I am hoping to find the same problem that raymond bagwell found. I hope it is not a problem with the transmission.
raymond bagwell
09-21-1999 21:34:24
the clutch disk had come apart causing the clutch to lock up.
John
08-31-1999 04:30:58
Sounds like the clutch may need adjusted. I suggest going to Ebay and buying an original owners manual Link
I>Link can send you the procedure if you like.
