Identification of tractor
Len Cowin
06-01-2001 05:07:47
My Name is Len and I live in South Australia.
I am seeking information for a friend who has a tractor and is trying to restore same.
It seems to be a strange one and not easy to identify.
It was manufactured in England under licence.
The Gear Box markings are County Gear Box with markings of Formoco 4COG13 and number 48D969553 stamped on the plate where the gearbox joins the motor.
The Engine is a six cylinder Diesel with a block number S450355 Fomoco 548E 6015.
Casting number 5826.
The head has the markings Ford 510E-6050-E FL.
If anyone can help it would be greatly appreciated.
So far I think it may be a 1964 Fordson County.
Can someone help with specs for above
Thank you
Len.
klaas postma
07-07-2005 07:18:03
 Re: Identification of tractor in reply to Len Cowin, 06-01-2001 05:07:47
Ford 510E-6050-E FL
we have a tugboat with the same enginine
marinized by lehman perhaps you can get there som more information about the original tractor it is build for
we have a leaking head so i was looking for an adress where i can gat a new packing for the head. mebay you can help us???
Jan Emanuelsson, Sweden
12-18-2001 05:31:39
Hello! Yesterday I went to a farm to buy a an electric generating set.The prime mover was a diesel engine of type Ford 510E-6050-E FL.I would appreciate if you could give me som more information about this engine. Is it possible to get spareparts and so on.
Best regards
Jan emanuelsson
Brian
06-02-2001 02:13:18
Len,
Sounds like you have a County Super 6 based on the old grey wheeled Super Major and fitted with a Ford Industrial diesel. This tractor has all Super Major parts except for the pinions either side which drive forward to the front wheels. These tractors were subject to breaking up of the final drive pinions and large gear wheels in the rear axle. This was always preceded with the hydraulic lift dropping after the small metal particles scored the ram cylinder. All the ones we worked with only gave this problem, the engine and gearbox never seemed to fail but the rear axles gave problems. Operators who waited till the wheels on one side were spinning like mad then slammed in the dif. lock were the biggest pain.
County made two tractors in the range, the Super 4 which was all Super Major based and had a normal Super cowl and grill, then the Super 6 as above. This had a steel cowl with the headlights right in the top. The cowel was just a bent plate rather than the Super shape.
regards
Brian
Manuel
06-01-2001 16:36:28
Hello Len,
There were several County models. 4wd & crawlers. Basically they were based on standard Ford tractors with the 4wd or crawler conversions. The smaller ones used the standard 4 cyl Ford tractor diesel eg 654, 754 & Super 4. [the 854 was turbocharged] The bigger ones used the 6 cyl Ford industrial motors eg 954, 1004, 1124 & super 6.
With the model Nos --the first 2 or 3 numerals give HP & the last 4 always means 4wd.
The 6 cyl diesels were 330ci & 363ci in size.
I hope this helps. I am in Aust also.
Regards, Manuel
