Interested in info on major diesel
Bruce Harle
06-13-2001 12:29:40
I just found a major diesel for sale nearby. I know very little about it. I like the idea of a small diesel utility tractor. I have a small hobby farm and plan to use it for mowing, moving round bales (small 800 lb. ones) and some dirt moving.
Somer things about it: Engine rebuilt 4 years ago, minimal use since then, all fluids replaced 2 yrs ago, brakes re-lined.
I would appreciate some information, especially the following questions, thanks in advance. Anything you think I should/ or would like to know that I haven't asked, please add since I admit I am a beginner with Fordsons.
1. What is the horsepower? I've seen 40, 45, and 65 in various places in the discussion forum.
2. Along those lines, what would the 3 pt category be?
3. How much would this weigh? (for hauling purposes)
4. 12V system? One or two batteries?
5. What is the difference between Major diesel and Super Major diesel?
6. How are the hydraulics on this? Known to be strong, weak, average. Problems? As mentioned above, I hope to pick up 800 lb round bales with 3 pt. I currently do this with an Allis WD so I think this should.
7. How would one assess the injection pump?
Brian
06-14-2001 13:27:14
 Re: interested in info on major diesel in reply to Bruce Harle, 06-13-2001 12:29:40
Bruce,
Does not sound too bad a buy at the right price.
1. You have not quoted any numbers and 1958 was a year of change. If the tractor was built before August it is a Fordson Major Diesel rated at 44hp.
If built after August it is a Power Major and rated at 52hp. Quick check. If throttle down by right leg = FMD,if under steering wheel = PM
2. Lift is Cat 2.
3. Weight = 4420Lbs
4. 2 X 6v total capacity 138 AH
5. Super had more sophisticated hydraulics with draft and position control.
6. Super more prone to problems. Major simple straight up and down. Neither are really complicated. About average.
7. Good. Few faults.
8. May or may not have "Live" hydraulics. If it has "live" system clutch parts will be a major problem.
We on this board love these tractors so our comments could be biased. If it were me, I would buy it if the price was right.
regards
Brian
Bruce Harle
06-14-2001 13:50:04
 Re: Re: interested in info on major diesel in reply to Brian, 06-14-2001 13:27:14
Thank you for the information. It really helps.
I was wondering if it was made after August '58, what other differences would there be? i.e. what makes the Power major different? obviously horsepower.
There are no hydraulic connections on this. Is is hard to connect into hydraulics for 3 pt and and a control valve and connections to run an external cylinder, such as a disk?
Is the PTO live?
Thank you again for the help.
Regards,
Bruce
Brian
06-16-2001 01:51:06
 Re: Re: Re: interested in info on major diesel in reply to Bruce Harle, 06-14-2001 13:50:04
Bruce,
It was mainly the hp and a few cosmetic changes like the movement of the throttle position. It was not until the Super that the introduction of dif. lock and the new hydraulics that major changes took place. Fordson tractors were "developed" over the years with minor changes to engine, gearbox or rear ends rather than big wholesale changes.
Live PTO was an extra so it is impossible to tell from a distance what you have. The tractor would usually have a badge on the front saying "Live PTO, Live hydraulics", The clutch pedal would have a bracket under the foot plate with a pin to restrict the movement of the pedal. This is so you would not stop the PTO when working with a loader (stopping the hydraulic pump).Check your tractor by engaging the PTO and seeing if it stops immediately you put the clutch down a short distance or whether you have to put the clutch right down to stop it. Tractor should stop before PTO if live clutch.
On both the FMD and PM the hydraulic connection is under your left leg pointing at the mudguard on the opposite side to the control lever. Just remove the plug and connect. The service with the least load takes precedence ie either the lift arms will lift then the loader or the other way round. Lock the lift arms up by mechanical means for best results.
regards
Brian
