FINALLY GOT IT BACK!
Burke
06-16-2001 11:47:58
Well, I finally got my Dexta back, the lift was totally rebuilt by my friends shop and can now lift the tractor off the ground!! The problem is that he also adjusted the injector pump timeing so that I don't need to use ether. It worked, but after running for about a minute, it starts skipping and blowing black smoke. It ran fine before! Does this sound like air in the lines to anyone? It still runs with plenty of power, but I don't want to run it in this condition. Oh yeah, there is no back fire through the air intake so it shouldn't be a valve. (these were also adjusted). Thanks
TMAC
06-16-2001 17:57:30
 Re: FINALLY GOT IT BACK! in reply to Burke, 06-16-2001 11:47:58
That black smoke is from a rich fuel mixture like in a gas engine. I think that is also true for diesels. If the fuel metering is right, it may be starving for air. Check the air intake system.
