Mine seems to be different. Front to back: Shaft the clutch linkage moves around, Behind that a filler port for transmission, Behind that a dipstick, I am assuming for the transmission fluid, Behind that is the flange connecting transmission area to the rear end of the tractor, Behind that is the dash & gear shifting lever. I see no other place to check an oil level. I do believe just in front of the left axle it is a sight glass, but it is hard to tell. In front of the right axle, there is a raised flat spot in the casting, but on the left it has a flange like plate with a sight glass looking bubble in the middle of it, bolted on. Should the rear end oil level be in the middle of the rear axle? That would be the level of this 'bubble'. I plan to part it on a side hill and remove it to see what is going on. Thanks for helping me with this. I am working on getting pictures on a web site so I can attach them and make it easier to clear this up. How are you sending the electrical schematics? Bruce
