Fordson major front lift
Joakim
07-09-2001 02:00:06
Have recently purchased a Fordson Major and i got a frontlift with it but it was not fitted on the major. My question is how am i suposed to get the hydraulic oil to the front lifter?
Have asked around for a part to get the oil out, but noone seems to know what i mean.
Brian
07-09-2001 07:26:21
 Re: Fordson major front lift in reply to Joakim, 07-09-2001 02:00:06
Joakim,
Under your left leg as you sit on the seat, pointing towards the mudguard, on the hydraulic valve chest, is a plug. This is the tapping point for hydraulic oil. Fit your adaptors for your loader oil supply in here. Make sure the lift arms are down before removing the plug or you will get covered in oil. Also stop the lift arms coming up to the top of their travel to get the best out of your front loader.
regards
Brian
Joakim
07-09-2001 09:30:35
 Re: Re: Fordson major front lift in reply to Brian, 07-09-2001 07:26:21
Thanks alot for the tip i will look in to it right away. I will keep in mind the thing about the lift arms.
Joakim.....
