Shaft for live power pump
Bob
08-16-2001 11:43:17
I am looking for a 4 bolt drive coupling, and a 13 1/2 in. long shaft. It has 10 splines on the drive end, and a woodruff key on the other. The coupling has 4 bolts holding it to the front pulley. Good used or new..Can't seem to find one... Thanks...
Bill S.
08-16-2001 18:20:51
 Re: shaft for live power pump in reply to Bob, 08-16-2001 11:43:17
Are you in the US? You could try W. C. Littleton 302-875-7445 and ask for Scott (used parts). You didn't say, but I assume it's for a FM, FPM, or FSM. My FSM has a pump shaft using spicer U-joints. Those parts are available fron any industrial power transmission supplier. Most machine shops could help you access them if you need to go that way. I know W. C. Littleton has an FM with a loader in their yard. There are a few other Fordsons that have been seriously picked already. Good luck. Bill
Bob
08-17-2001 07:10:25
 Re: Re: shaft for live power pump in reply to Bill S., 08-16-2001 18:20:51
Bill, Thanks for the reply and info. I have a 53 FM.with a Johnson loader on it. And I'm in northern minn. I forget this computer and tractor "stuff" is worldwide! Again, thanks for the phone #. I will be cking with them. BobH.
Bill S.
08-25-2001 22:32:32
 Re: Re: Re: shaft for live power pump in reply to Bob, 08-17-2001 07:10:25
Bob,
I was at W.C. Littleton's today and the pump drive shaft was still on that Major (maybe a Power Major).
Bill S.
