Looking for 1920 fordson ignition parts
marv in minn
08-29-2001 08:07:19
i am looking for the replacement buzz coil box connector boards, cover latches and a wiring set. this is my first fordson so am learning as i go.
(it has the trackson conversion)
i have already removed 2 gallons of mouse nest out of the radiator and found the holes in the gas tank bottom.
Fordson Exchange
09-25-2001 20:11:01
 Re: looking for 1920 fordson ignition parts in reply to marv in minn, 08-29-2001 08:07:19
Just about all the model T ignition parts are interchangeable. The coil boxes mount differently but can be adapted. Just a word of caution, the ceramic standoffs and studs behind the coil box are not all the same length. If studs and ceramics are too long, they will short out against the block. When ordering from a Model T supply house, make sure you stipulate that you need the short studs and matching ceramics. If you order from Langs Model T Parts in Winchendon, MA, they will know exactly what you are talking about. They have some used Model T coil box covers, early and late. These are all interchangeable with the Fordson boxes. If you need to replace the floats in the air washer, use the A14650 by Purolator. I discovered it a couple of years ago and posted it around the world for fellow Fordson enthusiasts. If interested I'll give you step by step instructions to make it work better than the original. Good luck, RLL
Bob C.
09-09-2001 09:28:37
Marv,
You might try MAC's Antique Auto Parts, www.macsautoparts.com, 1-800-777-0948. They have a great catalog of Model T parts and it contains the coil box, separate wood panels w/contacts or w/o plus wiring w/old brass fittings. Not sure if the wiring will fit Fordson, but would think coil box would. just call and give them dimensions.
Good Luck.
Bob
Dan Eichenour
09-07-2001 08:55:09
Hey, Marv! I have the sure fire cure for your woes...
...SELL IT! Get a Caterpillar. I have a trailer and will come take it off your hands. I bet you might even make a buck or two...
...Just kidding. Call me if I can help you with any more connections. Good luck!
marv
09-07-2001 09:11:57
 Re: Re: looking for 1920 fordson ignition parts in reply to Dan Eichenour, 09-07-2001 08:55:09
dan, i hear you've already got a belle city and a trackson to pick up. i wouldn't want to burden you with another one.
i've connected with dan zilm for any parts and help i need. thanks, marv in minn.
Mitchell Guffey
08-31-2001 19:14:34
You can get most of that from the Fordson House in Escanaba, Michigan. The phone number is 906-786-5120.
