Super Dexta- sounds like skip or knock?
Barney-Ga.
09-05-2001 09:05:31
My friend has bought a super dexta. It has to be started on either, and will smoke white smoke to start with, then will run weak. He thinks the "knock" is a rod, but I think the injectors are bad because we've run it too much for a rod to still be knocking. Last night we pulled the head and found a very wet injector tip on number 1 , and where fuel had been seaping around the outside of #1,and #2 injectors. the valves looked good, but we'll have the head checked. the springs on the valves feel weaker on #1,and #2 than #3. (both intake & exhaust). What we would like to know, is about the plates on the side of the head. the one on # 1 was in two pieces, and the other two still had the plate attached to the little "cup". On #1, the "cup" had beat a shiney place on the inside of the plate where it touches. Could anyone let us know if they have run into this? And if so, what was the problem/or what did it take to fix it. I'm taking the injectors to get them tested today.
Thanks; Barney
