Lever on Manifold of Model F
Machineryman
09-05-2001 19:50:06
I have a 1923 MODEL F, and can't figure out what the lever on the manifold is. It looks like it could be for shutting of the exhaust gas to the vaporizor plate, but don't know. can someone help?
Theman
09-06-2001 10:59:36
 Re: Lever on Manifold of Model F in reply to Machineryman, 09-05-2001 19:50:06
You're very close. I believe Ford called this a 'shunt.' When running on gasoline, it was to bypass hot exhaust gasses away from the fuel mixture tube that passed through the exhaust manifold. When running on kerosene, this valve was moved to add more pre-heat to the less volatile mixture. If your shunt works be thankful. Not many still do. I suggest you occasionally move the lever to keep things freed up. The lever on my '23 F has been long gone and the valve is rusted tight.
