INJECTOR PUMP
JT
09-10-2001 22:03:40
61 MODEL DEXTA JUST HAD INJECTOR PUMP REBUILT RUNS FINE TILL HALF OPEN THEN IT SMOKES AND MISSES. OUT OF TIME OR FUEL RUNNING TO FAST? ANY IDEAS WELCOME.
Craig
10-01-2001 09:44:57
 Re: INJECTOR PUMP in reply to JT, 09-10-2001 22:03:40
I had about the same problem on a '53 FMD. It turned out that the timing was off slightly. How does it act under load? If it runs better under load, I would suspect the timing. If it runs worse, you may have a fuel stravation problem.,
