Power Major Levelling Box
Chris
09-09-1999 02:55:06
Hi
Can anyone give any advice on the repair of a 3pt link levelling box, mine has a stripped thread in the mid-range. The top of the box seeems to have a large plate/core plug which might tap outfrom inside or pull if drilled / bolted and pulled with say a hub puller. If i can get it apart will it go back ok?
Is this a good thing to do or should i just pick up another box....
Regards from the UK
Chris.
Frank in MT
09-20-1999 07:33:16
 Re: Power Major Levelling Box in reply to Chris, 09-09-1999 02:55:06
I think that your best bet would be to buy a new one. Other wise it might cost you more to repair the old one. I have an NAA with the same problem, only I welded it because I didn't need it unlevel.
