Fordson Major
Bob
09-14-1999 08:44:15
I recently traded for a Fordson Major 4 cyl diesel,where is the ser # located? Everything seems to work fine, runs great, just a little weathered.I would like to know the value of this tractor. is there different manuals for different years? What diiferences are there?
Thanks, Bob
Nathan
09-20-1999 16:24:42
 Re: Fordson Major in reply to Bob, 09-14-1999 08:44:15
On later model Majors the serial number was located on the right side of the engine block. Near the front, just below the cylinder head.
Frank in MT
09-20-1999 07:28:17
The serial number should be located on the left side of the tractor, ( looking from the back), on the bell housing. You will probably have to take the bottom of the air cleaner off. The number should be stamped into the cast on the rib that connects the engine to the transmission
