Fordson major dsl serial number
dave
10-09-2001 07:21:14
I have checked where I think the serial number is and I get 79221p
I have a fordson major dsl but can anybody tell me what year and any more info about the tractor I really do have???
I would appreciate it heaps
thanks
Brian
10-09-2001 10:37:37
 Re: fordson major dsl serial number in reply to dave, 10-09-2001 07:21:14
Dave,
FMD Serial No. could be on flange behind starter or on plate on firewall just under bonnet hinge.
If you have found your no. under No.1 injector on the block re-check. It could be (08B)(7)79221. This would make it a 1962 Super rather than an FMD (or at least the engine from one).
On the other hand the missing No. could be (14)79221 which would be July 1958 and she could be one of the last FMD's built. The Power Major was brought in during July/August that year.
regards
Brian
dave
10-09-2001 18:40:40
 Re: Re: fordson major dsl serial number in reply to Brian, 10-09-2001 10:37:37
thanks for your help brian
I have found the seial number its 1273851
would really appreciate any info you can provide
once again thanks for taking the time to help
Craig
10-11-2001 09:34:33
 Re: Re: Re: fordson major dsl serial number in reply to dave, 10-09-2001 18:40:40
I have a Dec. '53 FMD as well, SN 1273782. I'm in the process of restoring mine, about 95% complete on the mechanical. If you plan to do the same, contact me if you run into problems.
Brian
10-10-2001 00:31:20
Dave,
Your Major was built in December 1953 early in the month.
If you look closly at the castings,axle, front casting, block etc. you will find, cast into the block, something like "N14U". This is the casting date code and will give you the exact date that casting was made " November 14th 1953". This is handy when identifying the Fordson Major ASP (All Spare Parts).
regards
Brian
