Starting a Fordson Diesel in subzero weather
Frank Rusnak
10-30-2001 16:16:49
I have a '58 Fordson Major diesel that I'd like to continue using in the cold MN winters. Anyone got any tips for starting the tractor when the temperature dips below freezing and beyond?
dave ryall
06-22-2003 11:17:15
 Re: Starting a Fordson Diesel in subzero weather in reply to Frank Rusnak, 10-30-2001 16:16:49
I start my 63 diesel dexta by simply removing the heater plug, then direct the flame of a blow lamp up the plug orifice and press the starter.She will fire up almost immediately and then pop the plug back in before the revs get too high....simple
henry schade
11-04-2001 21:14:33
A block heater on older diesels is the best way to go.
Zip
11-04-2001 18:00:51
Frank, just go to NAPA and buy a water heater that you can plumb into the water system and plug it in a few hours before you want to start it. Thats what us truckers have been doing for ages.
Bob
11-04-2001 13:20:30
I have heard hair dryers can warm an engine sufficiently. Stick a hair dryer in the air filter housing dont wedge it in tight or air cant escape and the dryer will burn out. naturally be careful of electricity, water, breakage etc as they are not designed for outside/workshop use, i am trying to get hold of a 12v travel hair dryer, not as good but will run off tractors battery and safe.
Brian
11-01-2001 11:28:29
Frank, Also look back further than Bruce suggests to a post "Decompressor". I posted some quotes from the Fordson handbook and the workshop manual.
regards
Brian
Bruce Harle
10-31-2001 10:35:40
You might want to check out the posting on page 2 of this forum that has the subject 'LEVER'. I found it interesting as to how it works to start the tractor in cold weather.
Bruce
Bob
10-30-2001 22:06:19
When we were on a dairy farm in upstate New York and had to use a diesel tractor in the winter,we installed a block heater in the water system,either in a soft plug or radiator hose.That saved a lot of strain on the starter and engine.
John A
11-04-2001 07:04:07
 Re: Re: Starting a Fordson Diesel in subzero weather in reply to Bob, 10-30-2001 22:06:19
My experience with larger HP tractors (150 +)
in the dead of winter, TX-OK panhandle. Two 4640s
one on a tub grinder the other a loadertractor.
we would change oil from 30wt. to 20wt. As long
as the weather was cold we sometime thined the DSL with Power Service. This and useing the blockheater we could start our tractors on most any morning. Both tractors sat outside not inside.
With thined fuel we didnt do any farming work, but
did usual chores,load&grind hay,string & rollup
electric fence,pull folks out who get stuck in the
mud snow,ect. Good Luck!!!!!
