Brian, Thanks for the comments. > The rear axle oil should be a Multi use 30/50 not 90W. Hmm... I picked up something called Trans-Hydraulic Fluid, and I don't know what weight it is. On the containers, it states that it is a "multi-purpose fluid for farm and industrial applications requiring a common transmission/differential/hydraulic fluid. It meets or exceeds the general duty requirements for all original equipment manufacturers. This includes ..." and it goes on, giving a number of tractor types. Hope it's the right stuff. I tried pulling up the 3 pt hitch lever while at idle, with the PTO and clutch engaged, and there is no difference in the sound of the engine, and no other sounds that change either. I have not yet put the new oil in. I have to find containers for the old oil, and (now that you mention it) some instant gasket. I'll try that screen as soon as I can. By the way, the lift arms are at quite different angles. I would have thought that the linkage between them would be solid, leading me to believe that they were mounted that way at some previous time for reasons unknown. Regards, Larry
