Looks like I have the pre-mod version of mounting the return line filter. It's attached to the pressure pipe. > The cross shaft pulls out from the side opposite the washer next to the centre casting. The splined area will not pass through the washer. Got it. It was quite a struggle. At first, I was going to try to drive it out the wrong way, because the parts that I bought were assembled a little differently than they were in the tractor. Just to be sure, the washer is on the side of the arm OPPOSITE the cam, right? When I say I drove it out, perhaps I should have said "I DROVE it out." After removing the end caps and the left side lift arm (I could not, and still can't, get the right side lift arm off the shaft). I put the bolt back into the left end of the shaft, to use as a sort of a holder for a 3/4" socket wrench, which I then commenced to pound with a 6 lb. sledge. It was slow going, and when the socket got to the level of the casting, I switched to pounding on a hardwood dowel to drive it out. It finally came free, and what was there was 'interesting'. On the right side, the steel bushing and one bronze bushing (the inner one) were in very bad shape, the bronze one broken, and the steel one worn and corroded. The outer bronze one was dirty and not oily at all. I pulled all the bits and pieces out, and discovered a passageway leading to the area where the control lever goes through the casting. It's full of dirt. Whether it's just ordinary dirt or dirt and dried oil, is not clear, but that whole side was not lubricated at all. This leads me to question 1. Is that an oil passage or just a passage that happened to be there? There does not seem to be any passage on the left side where the bushings go through the casting, though I won't know for sure until I get the three bushings out (all the left side bushings stayed in the casting). This leads to question 2. The outer left side bronze bushing is very tight in the casting. The inner bronze one is quite tight, but can be moved with tapping one side, then the other. The steel one between is very loose. Is there an easy way to get these out? Should I even bother trying? They seem to be in fairly good shape, unlike their brothers on the right side. If I need to clean out the passageway on the right side, how do I get the control lever assembly out? It appears to be held on by two bolts with a nut against a spring on the center shaft. Removing the bolts and nut was not productive. I guess the bottom line is that I could have it working pretty quickly, good enough to last the winter, probably, but I wouold like to do it right if it can be done. > If you leave the top link bracket on and lock the movement with two pins to the axle, you can lift the front of the lift and piviot it right over. Hmm... the 'top link bracket'... is that the thing with the two holes to hold the stattionary end of a top link? If so, it looks like it unscrews, and that it has some special purpose, attaching to the control lever mechanism. Any hints? Regards, Larry
