What is a 1952 major diesel worth?
Jim
11-17-2001 17:16:46
Years sgo, my dad gave me a 1952 (?) Fordson major diesel that I wore out most of my seat on when I was still on the farm. I was living in western Montana then and never thought I'd move back to Wisconsin. As things went the Simms fuel pum had some major problems that I couldn't afford to have repaired at the time so foolishly thinking it wasn't worth the effort to haul it back to Wisconsin when we returned, I gave the tractor to a friend. He spent a bunch of money getting the pump fixed and the tractor was running great the last I heard. My question is, what is an approximate value of this tractor? I would like to try to buy it back someday if my friend would part with it.
Craig Wissink
11-19-2001 09:36:40
 Re: What is a 1952 major diesel worth? in reply to Jim, 11-17-2001 17:16:46
Tractor prices vary a lot depending on the mechanical and sheet metal condition. I bought a '53 FMD in Oct. of 2000. It had good sheet metal, but needed painting and had lots of oil leaks which I am still fixing. Engine ran good and did not use oil, however it did need a new head gasket and head bolts. Pump was good. I paid $1900. It also need new rear tires. Hydraulics were good. Hope this gives you an idea of their worth.
Dann
12-11-2001 19:24:55
 Re: Re: What is a 1952 major diesel worth? in reply to Craig Wissink, 11-19-2001 09:36:40
Craig: Where are you at? Their is a tire recycling place just out side of Marion Ky on high way 60 that sells used tires for $20.00 each They had some nice 14.9.30,s and some good 16.9.30,s about a month ago when i was looking for 14.9.28S Don/t know phone # but its in the Marion phone book 1-270- Thanks!
Craig Wissink
01-18-2002 11:58:06
 Re: Re: Re: What is a 1952 major diesel worth? in reply to Dann, 12-11-2001 19:24:55
Dann, I'm in Minn. Already bought a new set of 16.9 x 30 rear tires. Thanks for the info.
