Super dexta 3 point lift
ken c
09-22-1999 20:46:02
resently got a super dexta was able to get running although it smokes a bit, but the 3 pointe will not move at all when raising or lowering the control. tractor has been sitting about 4 years. any suggestions!!!
JJ
09-24-1999 19:52:00
 Re: super dexta 3 point lift in reply to ken c, 09-22-1999 20:46:02
I would check the lift relief valve. Sounds like it's stuck open.
On the old perkins that I have done most of the time- cleaning the injectors has cleared up the smoke.
Ron
09-23-1999 03:38:39
Had the same problem with mine. Had to strip it all down and free up all the internal linkages.
Currently am putting it all back together with new o-rings seals and gaskets. Will then have to reset all the internal control valves.
It is not a very easy job.
