Hydraulic pump
frank
12-08-2001 15:40:36
I could use some info on hydraulic pump on a 1962 dexta. I tried Oscars and I couldnt find any.I believe mine is losing its prime but not sure if there are adjustments. thanks
mario zamudio maasberg
08-24-2002 16:47:30
 Re: hydraulic pump in reply to frank, 12-08-2001 15:40:36
solicito informacion donde puedo comprar una bomba del hidraulico para un tractor forzon super dexta agradeciendole la informacion gracias
Brian
12-09-2001 00:43:56
Frank,
Your Dexta pump would not lose its prime as it is under the oil in the rear axle. What symptoms do you have? Could be the wire mesh filter is blocked but this would be rare. Also you might have the wrong grade of oil in the rear axle.
Brian
frank
12-10-2001 03:14:16
 Re: Re: hydraulic pump in reply to Brian, 12-09-2001 00:43:56
the pump does hold pressure to the bucket and it takes a long time for rear hydraulic to work. i have regular tractor hydro oil in it.how do i access the screen? i just bought this tractor and someone else was messing with it.are ford n's manuals the same?
Brian
12-10-2001 08:51:23
 Re: Re: Re: hydraulic pump in reply to frank, 12-10-2001 03:14:16
Frank,
The fact that your arms and bucket holds up shows the valves are ok. The screen is really only accessable if you split the tractor at the rear axle.A good flush with kerosene and oil mixture and a quick run with this in the system may sort it out.
Have you changed the oil? It should have 20/30W in. The oil reccomended when the tractor was new was 80W but this was later modified.
If you have an auxillary service chest with a flow control on it. Little adjuster in thing that looks like a snail shell under the seat and above and behind where the loader pipework. The valve in this has been known to stick.
The manuals for the N's are not the same. Check here and on Oscars site. I would go for a Ford manual in preference but this is my opinion.
When you have posted before you said it works OK when warm. This sounds more oil or filter related.
regards
Brian
frank
12-10-2001 15:27:07
 Re: Re: Re: Re: hydraulic pump in reply to Brian, 12-10-2001 08:51:23
Brian thanks for your help. i forgot to tell you that someone had the pressure and return lines switched. i put them where they belong and things started to work. when the tractor is warm things start to work and then they stop,then they work again after a while but not easy. i appreciate your help. thanks
Brian
12-11-2001 12:19:01
 Re: Re: Re: Re: Re: hydraulic pump in reply to frank, 12-10-2001 15:27:07
Ok Frank, Getting a better picture now. Your loader is worked from a separate valve which has a flow and return from the tractor. To get the tractor to work this system:
1. The little Draft/Position control lever must be set in Draft.
2. The lift arms must be lowered and held down about 1".
3. The lift arm control must be up to the top stop.
This will cause oil to flow from the pump into the loader valve and should sort your problem.
If the lift arms get to the top of their travel they actuate a hydraulic cut off valve in the lift and switching off the oil flow.
Hope this sorts it
Brian
Bill S.
12-10-2001 17:24:33
Whereas you are operating a front end loader from the internal pump. Are you sure the oil level is adequate to keep oil above the suction as some volume is consumed/trapped in the lift cylinders as the loader is lifted. If that is good then I would suspect the oil is not proper and is getting too much foam. Proper hydraulic/diff fluid has antifoam additives. My front end loader operates from a dedicated pump on the front driven from the front pulley hub by a shaft, but it is a Super Major, not a Dexta.
