Injectors
neil
12-08-2001 22:05:25
How do you remove the injectors from a Fordson Major
Steven B
12-09-2001 20:55:59
 Re: injectors in reply to neil, 12-08-2001 22:05:25
1. Remove the rocker cover.
2. Remove the injector pump to injector pipes.
3. Remove the return pipe from the injectors.
4. Remove the rocker arm assy (Not strictly required but I find it easyier).
5. Remve the two bolts that secure each injector, be carefull not to drop them into the push rod chamber.
6. Use a large screwdriver to work the injectors loose and remove them in turn.
Reverse order of above for replacment, use new copper seals and adjust the valve clearance.
Steven B
