Seal on Pto shaft of FPM
Shane
12-23-2001 17:17:27
Hello and Merry Christmas,
Do I need to drain the oil in the back of the tractor to replace the seal on the PTO shaft and what sort of a seal is it? ( o-ring or proper oil seal or something else?)
Thanks in advance
Regards Shane
Brian
12-24-2001 02:17:06
 Re: Seal on Pto shaft of FPM in reply to Shane, 12-23-2001 17:17:27
Shane,
If you can get her on a steep slope with the nose down you will not have to drain much out at all. Draw the shaft out, its about 7' long. Remove the circlip from behind the bearing and remove the outer housing. Seal is in here. It is a proper seal not an "O" ring.
regards
Brian
Shane
01-02-2002 21:58:53
 Re: Re: Seal on Pto shaft of FPM in reply to Brian, 12-24-2001 02:17:06
Hi,
Excuse my ignorance, but how do you draw the PTO shaft out?
Regards Shane
Brian
01-07-2002 22:52:39
 Re: Re: Re: Seal on Pto shaft of FPM in reply to Shane, 01-02-2002 21:58:53
Remove the four bolts around the housing and pull the shaft. May need a little lever where the housing fits onto the rear axle. A tap in the join with a small chisel helps to start it.
regards
Brian
Roger H.
01-05-2002 10:40:59
The exact size of the seal is 1,5x2.508x5/8. The original #770055A, it has a wiper lip as well as the standard shaft seal, and was made by Aeroquip.
