How do you put oil into the steering coloum of a fordson dexta
Alan
01-03-2002 06:58:31
how do you put oil into thr sterring coloum of a fordson detxa?
dave
01-03-2002 09:24:20
 Re: how do you put oil into the steering coloum of a fordson dexta in reply to Alan, 01-03-2002 06:58:31
there is a hard way and an easy way. the easy way is to take off the central nut of the steering column and bit by bit pour oil down until it will take no more and oil starts to leak out. i understand the resevoir will hold a litre of oil, although i'm not so sure it will actually take this much. the hard way will involve dismantling stuff, including the fuel tank and i haven't tried this.
jim
01-06-2002 18:04:35
 Re: Re: how do you put oil into the steering coloum of a fordson dexta in reply to dave, 01-03-2002 09:24:20
I agree , however , while pouring oil into the column, turn the wheel,lock to lock which helps disperse the oil.
