Help with rear axle seal replacement
Frank
01-03-2002 11:01:49
I just inherited a fordson dexta. It runs but needs some TL&c, The turning brakes do not work so I took off the right wheel and everything looked dry and and the shoes looked good. I cleaned and adjusted the brake and it seems to work fine. I then removed the left wheel and the shoe and drum is covered with oil. I assume the seal is bad. Is the replacement a difficult job? Do I need to remove the bearing to replace the seal? Any help would be appreciated.
David
01-10-2002 05:01:42
 Re: Help with rear axle seal replacement in reply to Frank, 01-03-2002 11:01:49
My experience of replacing rear axle oil seals follows. The group helped get me started.
Link
is the first response I received and the thread can be followed from there.
I eventually added the following as a summary:
(hope it helps)
Just a short note to say the job to replace the oil seals and bearings on our Dexta is done and all looks OK after a few days work. (4
Hectares slashed, several rolls of hay put out etc)
My one addition to the standard oil seal/bearing replacement was to use a "speedie-sleeve" on the axle where the inner oil seals run.
These are stainless steel sleeves designed to press fit onto a shaft and provide anew surface for the seal. (the Speedie sleeve I used is
numbered CR99212 -for the 2.125 inch shaft, approx 1 inch long, it covered the 0.007 inch groove worn by the old seal)
If anyone wishes to buy bearings, the cone (The bit that goes on the shaft with the rollers in it) is numbered 387 and the cup (the outer bit
that goes in the hub) is 382. These are recognised by the bearing companies and the parts are sold separately.
In Aus the retaining rings were readily available at $Aus80 each, as were the inner oil seals. The outer seals, like the bearings are
standard items that could be brought from a bearing shop!
Getting the bearing off the axle (after removing the ring using a 3/8" hole drilled all the way through ... carefully avoiding the shaft)
required more push than I had. A friend of a friend helped out with a 30ton press that made short work of the obstruction to progress
(about 10 ton was needed to shift the cone on one side, the other about a ton).
Appropriate amounts of heat as suggested by Limpan earlier in this thread made reassembly a treat.
I did have to remove 1 x 0.020" shim to get the axle freeplay to within the 0.004-0.012" tolerance specified ... hope that was just wear
rather than me making a blue!
Thank you all for your help with information to allow the job to proceed.
regards David
Mark B
01-03-2002 19:41:03
Your tractor has 2 seals on the axle shaft, one on the housing of the rear end and the other is behind the bearing. Yes you will have to remove the bearing to get at this seal. I know of a place where you can get a manual for the dexta's if you're interested let me know and I'll check on it.
Mark B
Stephan
01-03-2002 11:36:36
Hi
Go to oscars fordson site It has a scan of the page you need
from the workshop manual
Hope this helps
