Doe Triple D
TH
01-09-2002 04:11:37
I've seen pictures of Doe Triple D's (two FSM's connected together) and I have always wondered one thing; Did the two engines run at exactly the same speed so the wheels in the two ends wouldn't slip? How it was arranged? I would think that it is almost impossible to make two engines run at exactly the same speed with just adjusting the throttle lever.
I would also want to know were all the controlling devices such as brakes, gear shift levers, clutch etc. connected together?
Thanks for the answers.
Steven B
01-09-2002 04:59:24
 Re: Doe Triple D in reply to TH, 01-09-2002 04:11:37
The rear engine was set slightly faster than the front. The front tractor had a seperate remote gear lever that employed electric solonieds to shift gears. Only the rear tractor had brakes. The clutch was linked together.
Brian
01-09-2002 11:53:04
 Re: Re: Doe Triple D in reply to Steven B, 01-09-2002 04:59:24
TH,
The original Doe had only a clutch connected to the back tractor. You put the front one in gear, set the throttle then went back to the rear tractor, put that in gear and away you went.
The thing then developed to either electric shift or a system worked with car brake cylinders to work brakes, clutch and dif. lock as well as the gears.
The ones I worked on had linked throttles so both tractors worked together and some had brakes on the front wheels as well as the back.
The best one I ever came across was a Doe 130 which was two Ford 5000,s joined. It was a Selectospeed with a long cable from a lever about 3' long connecting front and rear gearbox controls. You watched the exhaust on the tractors and the one throwing out the most black smoke was in a different gear to the other so the lever had to be jiggled to get them both the same. but I have never seen a better pulling tractor.
They made a version with a Ford 5000 in front and a Ford 7000 in the rear. This allowed the extra horse power to drive the hydraulics and power steering which were worked from the rear tractor.
I loved to get one in the field on some really heavy work after I had serviced it. Just for a little test run you understand. :0)
regards
Brian
TH
01-10-2002 05:07:43
 Re: Re: Re: Doe Triple D in reply to Brian, 01-09-2002 11:53:04
Thanks for answering. It seems that the Triple D must have been quite difficult to operate. But maybe it was worth the extra power.
brian
01-10-2002 07:48:57
 Re: Re: Re: Re: Doe Triple D in reply to TH, 01-10-2002 05:07:43
TH,
Not really they were a "pussy cat". In "Memories of a Field Service Engineer 1" in the archives on this site, I tell a couple of tales about "Triple D"'s
regards
Brian
