There seems to be a contraciction in the Lindsays messages: Lindsay said in the message posted 01-14-2002 at 21:46:20 "The ONLY I say again the ONLY time the lines dont pulse is when you have a faulty injector!!!!!" Again Lindsay said in the message posted 01-15-2002 at 22:17:14
"You made yourself look like an idiot by not reading my message. You will notice that I said "the lines pulse all the time but it is more noticable when you have a blocked injector" or something to that effect." I thought I should add my 2 cents worth: I agree with Brian in the matter of pressures. If the injector opening pressure is 185 atu, there is no way the pressure could be higher in any point of operation. When the pressure goes to 185 atu the injector valve will open preventing the build-up of any more pressure unless the amount of fuel pumped by the injector pump is greater that can be passed from the holes in the injector in the same time.
I'm not an expert in this matter so I shouldn't have opened my mouth in the first place so this information could be wrong. This is just what my common sense tells me. Please feel free to correct this.
