Fordson Model F front wheel bearings (History)
Don
05-24-1999 14:59:15
The first model F Fordson tractors were assembled with ball bearings in the front wheels, later tractors were delivered with Timken roller bearings. While the roller bearings are interchangeable in the wheels, it is necessary to use the new style spindle body that has a groove in the thread end to take the tongue of a special washer similar, but larger, than the one used in the Model T car. If no means were provided for holding this washer the nut would tend to turn with the wheel, eventually cutting the cotter pin and allowing the nut and outer bearing to tighten or work loose... destroying the bearings if not the old style spindle.
