Replacing lift arms on Ford 2000 Super Dexta
Lynn Busby
02-06-2002 07:03:57
I need to replace the lift arms on my SD. I've heard that NAA ones will work. What other tractor lift arms will work on my SD? How much should I expect to pay for a set of used ones? Thanks, Lynn
Burrhead
02-06-2002 08:31:39
 Re: Replacing lift arms on Ford 2000 Super Dexta in reply to Lynn Busby, 02-06-2002 07:03:57
Yes the NAA will fit.
Any of the Ford or Massey arms you find with the following measurements will work.
The original arms are 31.5" center of front pivot to center of back pivot ball.
The rock shaft arms and sway chain hole is 15.5" on center from the front pivot. You can give or take 1" on any mount measurement and it will still be okay.
I bought my last set from a Massey dealer and they were $35 each for new arms. The MF parts man said they were the same as a MF 35.
I put a set on a neighbor's Dexta this past week that came from Tractor Supply. The TSC part number showed the arms to be for a 801, but the measurements were perfect for the Dexta.
