Fordson N Clutch Removal
Rick
02-14-2002 09:17:19
Looking for help on the removal of the clutch plate for a Fordon N (1934+/-). There appears to be a ridge that stops the part from sliding out forward. Any thoughts would be appreciated.
ADAM
02-14-2002 19:22:48
 Re: Fordson N Clutch Removal in reply to Rick, 02-14-2002 09:17:19
Are you trying to remove the clutch assy. from the input shaft? if so the splines might be worn in a manner that prevents it from coming off easily?
Rick
02-15-2002 15:49:56
 Re: Re: Fordson N Clutch Removal in reply to ADAM, 02-14-2002 19:22:48
Should the spline be smooth? The spline seems to be flared at both ends. I have the tractor split in two and I am looking in from where the motor was.
